Installing a tank type block heater on an M
Posted by Dr. Bert on November 29, 2011 at 11:45:57 from (72.36.56.185):
I want to install a tank type heater on my '49 M. Found a plug on the left side of the block just ahead of the carburetor and a plug on the left side of the water outlet casting. If I use the last mentioned, will the warmed water bypass the thermostat? Is there a bypass built into this casting to allow some water flow when the thermostat is closed? It is suggested in the archives to plug into the port in the head where the water temperature bulb is installed. Which would be best? Thanks.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
