Take it one step farther. Remove the starter, leave wires hooked up, ground the starter to frame with a jumper cable and then try it to see if starter engages and runs. From your description of your wiring, you have not included the push button starter switch. Hot wire from solenoid should go to key switch, through key switch when turned on to push button, from push button (when pushed) to the s terminal on solenoid. The other small terminal on the solenoid is a ign bypass terminal used only on spark ignition tractor. If engine is stuck like you indicate, activating the starter will only damage starter and ring gear etc if repeatedly done. When you have starter off you will also have the best possible place to try turning the engine over by using a bar on ring gear.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
