Well, with zero compression, my opinion is that the valves are hanging. Unless each piston has a hole in it. even sticky rings will provide a little compression.
So, check your valves to see if they have full travel and are closing all the way. Use a small brass hammer or similar. On each valve that has a loose push rod (ie. valve is closed), tap the valve and see if it moves. It should "snap" back with a distinct sound as it seats. If the valves don't snap back or make a sound when seating, you have valve issues. Could be corroded stems or rusted seats. Either will not seat and seal.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
