But hey, at least you get potpouri, all I ever get is mouse crap and corn!
As for the compression -
First, I'd say measuring it by amount of wind passing one's finger isn't exactly an accurate measure! Remember these are very low compression engines to begin with. The difference between "perfect" and "not so good" might not be detectable with a finger.
I'd get a cheap compression gauge and check it before wasting any time with it.
But let's say the compression IS truly too low.
I'd dump a little oil in each spark plug hole and retest it. If compression comes up, you've got worn rings.
Pull the valve cover, crank the engine and watch each valve. If they're stuck, it should be pretty obvious that they aren't coming back up when the rockers lift.
If they appear to be working properly - then check the valve lash. (don't get all super accurate, just a ballpark check) The valves could be coming back up to close, but never making it all the way to seat.
It's unlikely they'd be worn so bad that they'd be no compression - the engine would have stopped working before they got that bad. BUT it is possible somebody messed around with them and cranked them too far down.
If valve lash is in the ball park, and they're all moving, then I'd pull the head and take a look. Make sure the head gasket isn't blown apart.
Do a leak test on the head. Put the head on its side and fill the exhaust/intake ports with kerosene. Watch the valves. If kerosene is dripping past a valve, it's too worn to seal.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
