Posted by Ken from NW PA on December 09, 2011 at 16:58:46 from (96.235.248.11):
Just thought I’d clear up some misinformation I found in the archives. I recently found a 240 utility front on ebay. I found several posts that said it would not fit a Super C, but after looking at the pictures of it I figured I could make it work. The price was too good to pass up, it went for only $66 complete with tires. It’s not an exact fit, the C uses 2 bolts per side to hold the bolster to the block, the 240 bolster is taller with 3 holes on a side causing it to interfere with the water pump. A few minutes with a sawzall cured the extra height of the 240 bolster, then it bolted up perfectly. The ball of the wishbone was just a hair too far forward so I put a couple spacer washers under it. Of course I had to drill and tap the clutch tube for the plate attaching to the wishbone ball. Took about 4 hours. I just thought I’d pass this on. The 240 utility fronts are not in high demand and can be picked up very reasonably if you come across one.
For those that that claim a wide front is no more stable - that may be true on a smooth field, but I often use my tractor in the woods. Drop your one downhill tire in a hole when you’re on a sidehill. You’ll quickly find yourself in violation of the seat side up rule.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
