Posted by rustyfarmall on December 15, 2011 at 14:13:38 from (216.248.71.224):
In Reply to: sticking clutch posted by D Slater on December 15, 2011 at 11:48:33:
There is an access hole in the housing directly below the flywheel to give access to the grease zerk for greasing that pilot bearing, and if the engine rear oil seal WAS leaking, the oil SHOULD just drip out of that access hole. I suppose if that hole was plugged up, the oil would accumulate and eventually be enough to get on the clutch plate, and yes, that would cause some issues, but there are so many other places where that oil could leak out that it would not be very likely it could ever get on the clutch.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
