Posted by Owen Aaland on December 16, 2011 at 09:50:49 from (216.47.33.169):
In Reply to: Farmall super C posted by Janicholson on December 15, 2011 at 14:15:06:
If the condenser is only marginal and not failed completely it can function enough with full battery voltage to allow the engine to run. While cranking the voltage available drops down enough that there is not enough voltage available from the coil to, provide a good spark. A twelve volt system that uses a bypass on the resistor while cranking will not have this problem because the available voltage will actually be more than what is available during normal operation.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
