Posted by Owen Aaland on December 19, 2011 at 22:05:03 from (216.47.34.100):
In Reply to: m vibration posted by thetractorfreak on December 19, 2011 at 17:30:08:
Unless there is a piece of the flywheel missing the problem would more likely be in the pressure plate assembly. If I didn't see anything obvious I would remove the clutch and run it to see if it changes the vibration. Before removing the clutch you may want to rotate the PPA in the flywheel either 120º or 180º to see if that helps. If necessary you can balance the PPA by putting washers on the mounting bolts where it is light.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
