Posted by Janicholson on December 20, 2011 at 06:49:20 from (199.17.6.10):
In Reply to: Re: Drilling a shaft posted by clint s on December 20, 2011 at 04:19:00:
With this data, there is a need to grind off the nub flat. If the material is incredibly hard (it might be) EDM could be the only way to get it done, That would require it being removed. If it can be drilled, Putting a pointed diamond burr in a dremel tool in a bracket supported in a rigid clamping system centered on the end of the shaft. Drive the gearset from the other end while holding pressure on the dremel. This ground hole will be the center. Now do as described below, or set up a fixture to hold the drill axially with the shaft. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
