Mike, The mag should click at TDC Full advance! The pin that you engauge in your crank should be horizontal at TDC. Crank it and listen for the click is it at TDC? That is a starting spot with your timing. The float in the carb can be a real problem if it is not floating good. I have had no luck with the cork floats and the gas we use these days. I have changed most of mine over to brass floats. If it is getting to much gas it will flood easy. I have one right now that is to lean and I have to choke it 2 times than it starts. I would rather that than flooding. oldiron29
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
