Posted by Janicholson on December 20, 2011 at 17:30:20 from (96.24.99.126):
In Reply to: 656 ignition posted by Fixerupper on December 20, 2011 at 09:42:59:
A bypass can be made with a 5 amp mrated diode, and 12ga. wire. Put a connector on the starter side of the starter relay (assumes it has no S terminal on it) This will provide Bat volts when the starter is energized. Put the diode in series with this wire, and from there to the coil side of the ballast resistor. Make sure the diode is placed so the flow of electricity can only go to the coil, not from it. (I do not know which ground it has, so when setting this up, brush the connector that will go on the starter side of the solenoid on the bat connection. If it sparks like it is turning on the ignition it is correct. if it does nothing it is backwards. The diode prevents the ignition system from trying to run the starter motor! Very important. Jim
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
