Most likely it's the 4th/5th slider gear. The internal teeth that couple up to the differential drive shaft are probably worn to a nub from grinding the gears when shifting 4th to 5th. It could also be worn bearings on the transmission input shaft or the pilot bearing what holds the front of the differential drive shaft. In 5th gear the top shaft is coupled together so that it's direct drive from the engine straight through to the differential. Gears 1 through 4 drive from the bottom shaft of the transmission. To find out for sure what is wrong, you're going to need to pull the top off the transmission.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
