Not all changes came in that original box of bull gears, differential, tapered roller bearings on diff etc. After they still had bearing problems a new bearing package was introduced. I put in several to the same tractors I originally had put the update pkg in. The axles never did and still do not have tapered roller bearings. Flat roller bower bearing on inner and improved (with extra clearance for flexing axle) ball bearing on outer axle. The 656 has tapered roller pretty much all the way through and inner support on bull pinion shafts. Their bull gears are smaller in dia but much wider tooth profile. The latest lube tubes were not in the 560 original pkg either. That was an after thought. We had to drill holes in differential, bull pinion support housing when that tube was added.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
