Posted by LonM on December 22, 2011 at 15:34:48 from (69.165.30.204):
In Reply to: Re: H regulator wiring posted by Janicholson on December 22, 2011 at 10:03:59:
That pretty well clears it up- I connected everything like you said and it all works! What threw me off was there was a wire from the ammeter to the bottom fuse screw to power the lights and the field resistor in the box still had a wire connected to it. The L terminal on the VR had nothing and I had a unconnected wire (from field resistor in box) sitting near the L terminal. Apparently what had happened was when someone changed it over from a cutout system to a VR, they did not change anything in the light/ammeter box. It seemed to work just fine for years, but I decided to re-wire it because it was intermittently charging (bad insulation on wires). So in the process of re-wiring I came across this half messed up VR installation. Now it is done right- Thanks a lot for your expertise (wiring gives me fits but I am learning). Merry Christmas Lon Medbery Browns Valley MN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
