A 12 v coil will have 3 ohms to 3.5 ohms of measured resistance between the Small terminals (when not connected) a 6v coil will have more like 1.5 to 2 ohms. The variability is in the wires used (length and diameter) inside. I know of no resistors inside coils. They would produce heat and that is not desired. The resistors used on 12v coils with external resistor required are built to radiate heat. Ceramic blocks, or long wires embedded in wiring harnesses provide that heat sink. The 6v coils and the 12v coils for use with an external resistor are basically the same coil. Both will have the lower resistance. The bypass system, from the solenoid or relay, or starter switch, is designed to let the coil operate at cranking voltages between 9 and 11 volts for starting only. this gives hot spark, and keeps the resistor out of the circuit while cranking. (if the resistor was in the circuit, it would lower the voltage to around 4 volts (not reliable) as you have found out.) Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
