Re: Int harvester 4166 4 wd stuckin four(4) wheel steering
Posted by TedinNE on December 24, 2011 at 07:26:17 from (74.85.105.144):
In Reply to: Re: Int harvester 4166 4 wd stuckin four(4) wheel steering posted by Dewayne Brown on December 23, 2011 at 18:35:16:
As Dewayne said, check for the linkage rod for being bent.
Also under the right hand corner of the cab is a link arm with a pin through it. If the pin is sheared it will cause the rod to bend.I am not sure how you were supposed to replace the pin with a cab on. Was able to drill a hole trough the floor and drive in a new pin. If the pin is sheared It will continue to bend the kinkage. Learned this the hard way.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
