Farmall C 12-volt Conversion with Magneto
Posted by Keven McNeice on December 24, 2011 at 13:41:12 from (216.26.208.44):
Hello everyone, Merry Christmas,
I have a Farmall C with electrical issues. It
runs, but will not charge. It has a Magneto and a
Delco-Remy alternator. Not sure if I have to have a distributor for a 12 volt system, but this is how i got the tractor.
I followed the 12 volt
conversion diagram for everything but the wires
that go to and come from the IGN switch, which is
where I followed the 6 Volt Diagram, and left the
Number one terminal alone.
See 12 volt Diagram here:
www.productionfield.com/Extra/05-
See 6 volt Diagram here:
www.productionfield.com/Extra/04-
I was curious if anyone had a suggestion for what
I should do? We have tested to see if it charges
at the alternator, from the Bat terminal to ground
and only got what the battery had (11.95 volts)
Also, the tractor runs at an inconsistent RPM
occasionally. Could that be spark plug problems? I
have replaced the rings, honing the sleeves in the
process. The spark plugs are newer but were used
when I had a busted oil ring on the number 2
cylinder so I will replace them unless someone suggests another approach.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
