Re: HELP!! Can my Dad's Farmall sit without causing too much damage?
Posted by Farmer Bob on September 04, 2000 at 21:45:44 from (208.49.9.224):
In Reply to: HELP!! Can my Dad's Farmall sit without causing too much damage? posted by Jason on September 04, 2000 at 20:59:28:
Jason, You will probably regret it later if you let the tractor be sold now. Leaving it sit for awhile longer is okay but with a few precautions: Next opportunity you have here's a partial list of things to do...others can add more if I don't get the complete list here: 1. Remove the spark plugs and squirt about a two tablespoons of motor oil in each cylinder/rotate the engine ( with the crank) as the battery is probably shot already. Reinstall the plugs only hand tight. 2. Disconnect and remove the battery from the box. No need to have acid leak out and further damage the battery box or chassie of the tractor 3. Drain the gas tank and the carb. Ensure the gas cap is on tight. 4. Put a can over the muffler so dirt or anything else can't get down in the manifold. Good idea even though it is stored inside. 5. I would jack up and block the tractor up so the weight is off the tires. 6. Depress the clutch pedal and block it with a 2x4 in the disengauged position (Forward), This will help from seizing the clutch disc to the pressure plate. 7. Depending upon your winters...make sure the radiator is protected with antifreeze. 8. Disconnect the coil wire leading to the distributor. 9. Put a tarp over the tractor and secure it, leaving the hand crank in the hole in the front bolster. This is for when you are home on break from school you can go out and turn it over a few times. I have wished several times that I still had any one of our four farm tractors that were sold in 1969 when my Dad quit farming. I grew up on those tractors and have many memories both good and not so good, as a kid driving those Farmalls. But that's all I have are the memories. Good luck//FB
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
