maybe. !,5 is not too drastic, the key issue is whether it is slipping. If not (and it is not making noise, and not preventing shifting) let it be. Clutches wear thinner. Unless the cross shaft is bent, or the Fork pushing the throwout bearing is loose or partially sheared on the shaft, a clutch will get less and less freeplay as it wears. Making the rod too long, not too short. Mis adjusted fingers on the Pressure plate, or a flywheel cut that didn't reestablish the step depth, wioll also make the fingers move too far in towards the Flywheel. (your rod too short issue. I hope this helps. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
