I would not adjust the valve lash on that engine with it running, but, that is the way IH motor trucks always said to set them back in the days. The only time I ever had a feeler gauge chewed up was on an old chevy 235 power glide with hydraulic lifters. I had the bright idea (was young then) that if I just gave them valves a little bit of clearance beyond the maximum range of the hydraulic lifter that engine would quit burning valves. Well, that camshaft for the hyd lifter was pretty nasty about closing the valves apparently and just chewed up the gauge. Needless to say, that experiment did not work. Later on, found out the valve seats were all poorly fitted (loose) in head that had been worked over by a local machine shop. We found a different head and no more valve problems. Actually, setting valves with engine running gives you the reading off the true heel of the camshaft lobe. A lot of lobes have the ramp starting a considerable degree from the very heel of cam so when you have piston tdc comp stroke you are part way up the ramp. That is why I never use the simplified method of adjusting on several cylinders at only two positions of crankshaft. You can run into some measurable differences in clearance on different cylinders that way. Not much, but it can happen.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
