Posted by pete 23 on December 31, 2011 at 16:40:01 from (74.32.238.142):
In Reply to: M will not start posted by Dudley Brand on December 31, 2011 at 15:20:02:
If it will run by spraying gasoline into intake of carb like you indicate I would just screw the main jet out a few turns to try. Once you get it running you reset it. There is no 100 per cent accurate setting for a dead engine, it is a starting point. Get her warmed up, run wide open , turn it in until starts to lean out, back out to running good and give it another half turn or so. Idle screw, set for best idle. Can be anywhere from half turn out to couple of turns depending on carb and engine conditions. And, the idle screw is air, so the farther out on that one the leaner on a M.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
