Posted by Rod in MN on January 03, 2012 at 05:07:46 from (66.242.67.252):
In Reply to: M Governor Adjustment posted by Rod in MN on January 01, 2012 at 12:17:31:
Hi took the Gov off the tractorto check out all parts inside thet all were good. The Gov housing did not have the bumps showen in the book. Made a longer bolt to adj high speed stop as per IT book to get no pressure on spring. Checked pin in upper rod pin was losse. start a run tractor adj carb but no high speed. Installed short bolt to adj stop had lot of spring presser on spring.Ran tractor could get high speed. But why so much spring presseur on spring it works ok ????
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
