Later pumps are tighter than early pumps but I don't have the year or serial number break.
I have never taken a countershaft driven Liftall apart. But there has to be a pressure relief valve in there somewhere. I assume it can be adjusted for higher or lower pop-off.
Countershaft turns at 37% of rated rpm of 1400. That would be 518. Seems very slow for a small pump. I think it might be alright at 2000 rpm but YMMV. If it seizes up, run the next one at 1500 rpm.
I'm thinking I wouldn't mess with the pressure. But would overdrive it. I would also use a 5" or 6" cylinder on a log splitter as the psi on those pumps is less than 1000.
All-in-all, I probably wouldn't use the Liftall for any continuous use. It would do OK on something like a lift in your shop or on some vehicle. But you could get something like pallet stacker reservoir/pumps/motors that will work better.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
