Posted by screwstick on January 09, 2012 at 08:25:33 from (174.24.15.42):
In Reply to: C-60 firing posted by KP2n LA on January 09, 2012 at 08:17:43:
The cylinder are numbered 1-4, front to back. With the front pulley on the timing mark, either 1 or 4 will be at TDC on the compression stroke.
Remove the #1 spark plug and with your thumb over the hole, rotate the pulley till you feel the pressure (compression) building up and continue to rotate the pulley till the you reach the second timing mark. You will now have the #1 cylinder TDC on the compression stroke. With this set, look over to the distributor rotor button, it should be pointing to the #1 tower, or about 1 or 2 o'clock.
This post was edited by screwstick at 08:28:39 01/09/12.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
