Posted by CNKS on January 12, 2012 at 17:05:48 from (216.144.104.128):
In Reply to: downsides to an H? posted by soundguy on January 12, 2012 at 10:53:05:
Common problem is jumping out of 5th gear. 5th is direct drive, splines get worn from repeatedly grinding when shifting, or end of shifter is worn. Front end wobble in 5th is common. Clutch and brake pedals may need new shaft and bushings. Pull from side to side to see. Gas tank may be rusty inside causing outlet to plug. All these are not defects, just normal wear after years of use. Make sure the brakes work before backing off a trailer. More of problem with the disk brakes on a Super H, rather than the band brakes on an H.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
