Posted by gurneejoe on January 18, 2012 at 05:09:08 from (205.188.116.73):
In Reply to: 2514B BACKHOE posted by BOB ONEILL on January 17, 2012 at 18:42:23:
If this is the same as a 2500B I would look for bleeders at the top of each axle housing or just above the housing on the main case. If you open them when the engine is running they should slowly flow until the air is out of the brake pistons. There are brake discs and piston between the axle and the case. In order to replace the piston o-ring the axle housing comes off. They use oil from main reservoir so make sure it isn't low. It would be obvious if the hydraulics are noisy or jerky. You could open the bleeder and push the pedal with a helper but engine should be running to keep the master cylinder suppied with oil.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
