Re: farmall md fuel systems
Posted by BruceS. on January 21, 2012 at 06:34:29 from (76.15.41.164):
In Reply to: farmall md fuel systems posted by jim warehime on January 20, 2012 at 18:44:07:
When I got my MD, someone had installed a fuel bowl on the diesel tank. I don't know if they did that to correct the problem you are describing or not. My tractor runs just fine with that setup. YOu might consider it if all else fails. The one drawback is that your fuel line will probably not line up with the fuel bowl fitting. Mine was cut off a few inches and replace with a rubber hose. Certainly not factory, but it's never been a problem. As for the carb drain, something as simple as teflon tape might fix it, or try anerobic sealant (available at NAPA). That stuff really does work wonders on hard to stop leaks.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
