International or Farmall makes some difference. i'm not familiar with the non 3 point models but my guess is there is only one pump inside the center housing that feeds the power steering and then the remotes. The first step should be a pressure gauge plugged into the quick coupler(s). A good guess would be the priority valve that allows fulltime power steering pressure is malfunctioning. It's also possible the relief valve for the remote valves is stuck open or just broken. if you have more than one remote pair, make sure you have the correct combination of hoses paired to the couplers and then see if the behavior is only with one valve or if it is on all of them. look for check valves or restrictor valves between the cylinder and the couplers that could be screwed up too.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
