Re: Putting duals on 400/450
Posted by CenTex Farmall on January 24, 2012 at 19:59:48 from (166.147.67.89):
In Reply to: Re: Putting duals on 400/450 posted by sflem849 on January 24, 2012 at 18:32:42:
I didn't know if there would be clearance issues between tractor and tire with the wider rims. I have a 400lp with the "correct" wheels and rims and 14.9 tires and a non-running 450lp with the same wheels and tires.
What I want to do is put duals and a heavy front blade on a tractor and use it to help clear some overgrown land. I also have a basket case 400lp that I would do this on as the sheet metal is junk and the motor is stuck and third gear is out in a bad way. I could resurrect the poor thing and build a heavy front end for it and use it instead of beating up the nicer machines.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
