Oil and glazed surfaces will do that. There should be material remaining above the rivets on the bands, if bonded, the bands should be more than 3/32 thick at any location. To remove oil contamination, use brake clean spray to remove external oil, then heat the bands with a propane torch (not oxy!!!) until the oil is baked out, Do not heat radically, just maybe a 3to 4" length moving the torch all the time. When the oil stops coming out, wipe down and rough the surface with 250 grit paper. The seals are removed from the outside, do not take out the carriers without removing the bull gears!! Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
