There is no provision for adjusting the vertical end play of the upper bolster shaft. The weight of the tractor keeps it in place. If the noise is really a problem you may want to consider slowing down a bit for the rough spots.
The end play can be controlled by installing washers between the steering gear and the upper bolster. You must maintain a little end play because the gear has a taper fit on the upper bolster shaft which must get tight before all the end play is gone while tightening the retaining nut.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
