Farmall A starts hard
Posted by dahlin on February 04, 2012 at 13:47:08 from (184.158.16.185):
We have a 1940 Farmall A I've had it for about a year and a half. We put on a new carburator, new plugs and plug wires. Had the magneto off and cleaned and checked. It checked out fine. The tractor when it's cold won't start. Wants its started and warm if you shut it off it will start right up again. When you drive it down the road it has good power and does not miss a beat. I did a compression test with the engine at operating temp and all four cylinders tested out to be 90 PSI. I then did a wet test and the results were just about the same. I'm stumped as what could be the problem. Need HELP!!! Thanks for your help. Randy
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
