There may be confusion between steel wheels and rubber tire rims. If you see rubber tire rims bent, there is a metallurgical problem with the Australian rims, I have seen a few bent rims but they were from smashing into solid concrete in 4th (no longer hanging around, so no issue) I have never seen a IH front or rear rim bent from field work, and there are bowling ball sized rocks in the fields. If they are steel "tires" they should be 1030 or higher carbon steel and 1/2" thick. Rubber tires add a cushion between the drive train and implement. Gears and bearings last longer. Jim
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
