Re: Help with my 1958 International TD 14
Posted by Josh Baker on February 07, 2012 at 16:58:07 from (67.142.170.24):
In Reply to: Re: Help with my 1958 International TD 14 posted by FC Andy on February 06, 2012 at 18:19:16:
I purchased a bulldozer this fall, an International TD 14. It’s around a '58. It has a running issue and I haven’t yet found anyone able repair it. The gentleman that owned the machine previously was never able to start it on gas. He had started it with ether on the diesel side. When started, it does run very well. Once I bought it, I've been working on repairing the problem. I will tell you exactly what I've done. The first thing I started with was cleaning the carburetor. There was a lot of rust and debris. Someone was there before me and tried to silicone it back together. I’ve removed all that was dirty and bolted it back on, and also cleaned the gas tank. When I started it, it had a very bad skip; actually was running on 2 cylinders. I was able to keep it running for several minutes, but eventually it petered out and stalled. That’s when I learned that the mag needle was failing. I pulled the mag off and had it repaired. When I got it back, it worked perfectly. I reinstalled it, attempted to start it with no prevail. I also replaced the sparkplugs and wires, and again it failed to start. When I was looking at the intake, I noticed there is apparently a ''flapper'' inside to shut the vacuum off to the diesel side so the vacuum has to be pulled threw the carburetor so it is able to get gas for it run. I haven’t pulled the intake to see its working properly. I would like to talk with someone before I tear into something that I don’t have too. It would be very much appreciated to hear back from you or if you know anyone that could aide me through this dilemma
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
