Myself i have never done a narrow rim , i have done several 12 inchers. as you have a nice flat area to split and ya split the side away from the hole for the valve stem . I have a weld shop that has rolls that make me the bands and they always make them and inch or so longer . Then ya just place them on the rim and tack then ya put the bead on the band and tack it . Oh one other thing here always put indexing marks on both sides of the cut and keep them aligned . I also like to keep a little air gap between the band and the rim and bead part of the rim so that when welding ya get 100% penetration. Then also weld both sides . Keeping weld build up down saves time grinding . I cut the rim mounted on the tractor and use a steady rest to get the best cut and as straight as i can the indexing makes help with keeping the cut in register . I prefer M I G welding over stick but i can do it either way. With mig i run l56 and AG 25 with stick i use 7018 After i have it all tacked together it goes back on the tractor and is welded there . I have split both 34 and 38 inch rims . On the newer style rims that have the double mounting ribs we split them down the middle between the ribs.. But on the old 12 inch rims on M's we just split the one side . On my S/MTA i put a 4 1/4 inch band in it to mount the 16.9's . You ask why a 4 1/4 inch band ?? well by the time you make the torch cut and grind you can loose more then a 1/4 inch easy i was a 1/16 th short of 16 inches when done .
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
