Posted by Janicholson on February 14, 2012 at 20:58:04 from (96.24.99.126):
In Reply to: fire crater or step head posted by Roger Tomfohrde on February 14, 2012 at 16:27:33:
Fuel use improves with efficiency of pumping and thermodynamics of the combustion chamber. Higher compression improves the expansion ratio. Thus the burning fuel has a greater percentage of volume to expand into from a smaller chamber. The surface to volume ratio of the chamber amounts to the relationship between the TDC volume compared to the surface area exposed to that volume, ie, if the chamber were perfectly cpherical, it would have least surface/volume, if thin areas and convoluted surfaces are present it has more surface to volume. Minimal surface area allows less quenching of the flame and more complete combustion. Strange shapes can produce higher unburned HC and lower net output. BUT-- squish areas and shapes do (or can) contribute to turbulance in the chamber and somewhat better combustion than open chambers. The reality today in newest technology engines provide direct injection. This allows a correct easily ignited mix at the plug with fuel free air near the surfaces reducing unburned HC, and making a gas engine nearer diesel in efficiency and far better in HC emissions and far fewer soot particulate issues. I wpould go with the piston that has the least surface area, but highest compression. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
