Use standard torque unless a special torque is given.
Taken from the IH repair manual GSS-1036-E W/Revision 2.
Special Torques (ft. lbs.)
Bearing cap bolt --------------- 80
Crankshaft pulley nut --------- 95
Flywheel bolts ------------------ 60
Thrust plate bolts -------------- 38
Idler gear shaft bolt ------------88
Crankcase front plate bolts --- 38
Crankcase front cover bolts -- 90
Connecting rod bolts ----------- *
Cylinder head bolts ------------115
Oil pump mounting bolts ------- 22
* Two types of 3/8" x 24 connecting rod bolts are used. These bolts can be identified by appearance and each type has a different torque specification.
1. The PLACE bolts has a head that is either "notched" or concave. Also the shank and thread diameter is nearly the same. This type attains its tension by bending the bolt head It should be torqued to 50 ft. lbs.
2. The PITCH bolt has a standard bolt head with a washer face. The thread diameter is larger than the shank. This type of bolt attains its tension by stretching the shank. It should be torqued to 45 ft. lbs.
This post was edited by Owen Aaland at 18:04:58 02/18/12.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
