The side remotes by the brake and clutch pedals share the controls with the remotes in back. the left lever controls both the rear left pair and a front pair at the same time. the right lever controls the right rear and the other front pair at the same time. I think it goes left/left and right/right, but there are tractors that are the opposite, or where only one front is used so it could be paired with either rear. you should only use one remote pair per front/rear circuit, except for front and rear implements that need to be lifted at the same time. The control levers have a float position all the way forward, so if they latch forward, they might be in float mode which is no pressure. They like to stay in float mode more so than pressure in the forward positions.
You need to check into how the tractor is plumbed, and get good advice on how to make it do what you want to do. Sounds like you have some hoses crossed or are trying to do more than the system is capable of.
If you have an additional valve external to the tractor for the loader that is plugged into the remotes, The loader will only work the way you want with the tractor lever tied into a pressurized position. This extra valve also needs to be plumbed properly to prevent popping relief valves. The remote fitting that will be pressurized needs to be identified. It will have a hose going to the IN port of the external valve. In the simplest way, the external valve only needs to have an OUT port which needs to be attached to the mating remote fitting. If you have a valve that also says BYD on a port, you need to find out how that port is configured, as it gives plumbing options for various types of systems by changing the plug or bushing in that port. If the loader came off a JD, you have the wrong kind of valve setup--this can be easily remedied with most external valve setups. If the valve came off another make of tractor with open center hydraulics like your 706, then maybe you need to utilize the BYD port in addition to the OUT port. It would help to know how this setup was used prior to your use.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
