Posted by Owen Aaland on February 21, 2012 at 22:02:08 from (216.47.35.16):
In Reply to: 656 resistor posted by Jamie656 on February 21, 2012 at 14:38:30:
If it has a separate ignition resistor it will be located by the ignition coil.
During the production run of the 656 with generators there was a change in the wiring harness so that the resistor was built into the harness between the ignition switch and the starter solenoid.
Here is how to tell which system you have. There are two small terminals on the starter solenoid. The "S" terminal will have only one wire and that is the one that provides the power to engage the solenoid switch. The other terminal, marked with an "I", will have either one wire or there will be two wires crimped together in the connector. If it has only one wire you should have a separate resistor at the coil. That harness will also have two wire together at the coil. If it has two wires the resistor is built into the harness and you do not use another one at the coil. That is the later harness and will have only one wire at the coil end.
Tractors with alternators all had the resistor built into the harness for the ignition system but they had another resistor at the regulator for the charging system.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
