Posted by John T on February 24, 2012 at 05:41:29 from (66.87.4.142):
In Reply to: electrical problem posted by farmalmarkmark on February 23, 2012 at 18:24:50:
First of all "wiggling" is no substitute for what I recommend which is to remove,,,,,,,,,,clean and wire brush all shiny,,,,,,,,,and replace each and every battery and starter and switch and especially FRAME GROUND cable and connection then try it again.
If when you push the start switch the lights dont dim down and/or the voltage dont drop much the problem may be the start switch contacts are burned and pitted and resistive (but still could be maybe starter brush problem)
However, if the lights dim wayyyyyyyyy down and voltage drops drastically IF ALLLLLLLLLL CABLES N CONNECTIOSN ARE GOOD???? Id suspect a starter problem instead of the switch
Yes you can by pass jump the switch direct to starter but thats a HIGH current jump remember and requires heavy jumper cables and good connections
Id suspect a cable or connection or ground problem BEFORE the rest
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
