adjusting the F-20 rod bearing
Posted by SDE on February 25, 2012 at 21:12:46 from (174.124.49.15):
I made a shaft that is .003 larger than the crankshaft journals. I put the connecting rod in a vise and then removed shims until the shaft was tight in the bearing. I then turned the shaft with a pipe wrench. After removing the shaft, I would scrape the bearing. I did this until the shaft showed that it was making contact on at least half the bearing surface. Some had two more shims on one side than the other. I put them back so that each side had the same amount. This is my first time working with babbit bearings. Am I doing it OK so far? I saw in the archives that you install them onto the crank so that they are tight and then add a shim to each side until they are loose. Will the way I did it work OK?.
Thank you
Steve
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
