Posted by screwstick on February 29, 2012 at 09:24:59 from (174.24.8.24):
In Reply to: Cub tie rod adjustment posted by Travis Troxell on February 29, 2012 at 08:56:49:
The clamp is only for extending the rod out to match the extension of the axle. Tighten the clamp back up in the same notch that the axle is set to.
To adjust the tie rod, the socket at the end where it attaches to the spindle arm is threaded with a jam nut. Loosen the jam nut, and turn the socket in to the desired toe in. Adjust the socket to where you have the front of the tire 1/4" closer than the rear of the tire. The screw at the end of the socket should be tight enough to limit the play to a minimum with a cotter pin installed to keep it in place. There is no adjustment at the ball socket end except for shims to reduce play.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
