Most Ms have a "belly pump," officially known as the "transmission-driven LiftAll." It is a basic one-way hydraulic system that only makes pressure when your foot is off the clutch pedal.
The pump is of course located in the belly of the tractor. There is a lever sticking out the right side of the tractor's belly, and a rod running up to the platform. There are also pipe elbows sticking out each side of the tractor's "waist", possibly capped off, possibly with hydraulic couplers attached. Pull the lever for pressure up. Push the lever forward for gravity down.
Hookup for basic lift is simple. Bolt the hitch to the tractor. Run a hose from the bottom port of each cylinder up to the front hydraulic connection on each side of the tractor.
Down pressure really isn't needed for moving round bales. It's main advantage is the hitch goes down quicker when there is nothing attached. The bale spear will be plenty of weight to make the hitch drop quickly. You will need a 2-way valve and some more hoses to set up for down pressure.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
