While many many many of the older 6 volt tractors were indeed Positive grounded (and then many switched to Neg at 12 volt except allllllll two cylinder Deeres 6 or 12 volt were Pos ground), theres no reason (if configured and polarized etc) they cant work at Negative ground. Way back before Neg became the standard Ford had a different idea then GM and Chrysler as I recall and there was some thought there was less corrosion where frame members were joined if Pos ground was used.
SPARK PLUGS they dont know or care if a 6 or 12 volt coil is what produces the several thousands of volts necessary to arc jump current across their gap. They fire at maybe 5000 to 15000 volts or so depending on the gap width and medium (fuel and compression) in which they operate NOT ANY 6 OR 12 VOLTS. They are designed to retain or dissipate x amount of heat to the relatively cooler head which is the plugs "heat range" and thats a mechanical and thermodynamic property and design cosideration NOT if a 6 or 12 volt coil is uded to produce the thousands of volts to arc jump current across their gap.
WHILE MANY OLDER 6 VOLT TRACTORS WERE 6 POS GROUND AND 12 WERE NEG, ITS NOT NECESSARY ANY 6 VOLT VEHICLE MUSTTTTTTTTT BE POS GROUNDED.......THE SPARK PLUGS ARE NOT NECESSARILY CONCERNED IF THE TRACTOR IS 6 OR 12 VOLT.........
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
