Posted by 460 training on March 10, 2012 at 19:50:26 from (173.213.142.69):
Bought 460 last summer. When I got it home, found it would start sputtering and die when worked, or throttle cracked open. Usually pulling the choke would save it. Checked fuel supply - good flow. Checked for air leaks - none found. Checked spark, intermittent - replaced coil and found resistor bad - replaced both and started running/responding good, but I really did not work it after that. Today I started using it to harrow, about 10 min in the problem seems to have returned. Now it will only run with choke on. I will go back through but am looking for other suggestions. Also this tractor has 560 engine (263 CI). Is it possible that it still has the 460 carb and not getting enough fuel? Are the carbs diff 460/560? Thanks in advance.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
