'cause the paint's shiny!!!!! I, at the risk of offending some folks would like to point out that "Completely Restored" should only be used on a tractor or other piece of equipment that has been totally disassembled I mean TOTALLY as in there isn't any two pieces still bolted or pressed together, every piece examined and measured AND REPLACED IF IT IS NOT WITHIN SPECIFICATIONS FOR A NEW PART, then totally reassembled and painted as it would of been when new. I'm guessing that your tractor has been partially refurbished and it'll need some additional repair or refurbishment. If you don't get a similar noise when you push the clutch in and press the Right brake pedal I would think you have a bearing issue on the right side or something loose or worn in the differential. If I were trying to figure it out I think I would jack up the rear end both wheels off the ground engine off and start turning wheel back and forth using brakes and such trying to narrow down where the noise is coming from.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
