Above that serial number, the head gasket does not seal on the sleeve. The sleeve has a very small flange and it is not to be pressed in the block so far that the flange contacts the block. That will cause sleeve to crack. That is the reason they tell you to use the proper tool as it will press sleeve in proper depth. The flange will protrude maybe .025 over block but less than head gasket thickness. The height is not all that important. The important thing is that it is not pushed in too far. The older engines you had to maintain the sleeve flange height to a very close tolerence as the head gasket sealed on the flange of the sleeve. I liked to stay on the low end of spec on them but all must be within that .002 of each other. And the new engine sleeve is a heavy press sleeve where as the older serial number engine has a light push. On them I normally go with a .002 oversize sleeve, hone block to get a nice light press fit if possible.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
