Like Pete said and i will ad to this . a 766 setting at a 100 Hp is a bit over fueled and being over fueled can cause washing of the walls and fuel not burning can turn to more carbon . Also along with fitting sleeves to block it is wise to FIT PISTONS TO SLEEVES today. One other thing about breaking in a diesel engine is HEAT , if the engine is not getting up to and above 165 degrees and better if it is running 185-195 range the fuel in not getting burnt properly . Making sure that the injectors are all working good also plays in how well your rebuild is going to play out. As for break in OIL myself i have never played into that . I run what is going to be run in that engine . And a better way for break in is TO RUN IT , Now not sayen to take it out and put her on the plow and plow 500 acres non stop but Chore work , haling manure moving bales spreading fertilizer grinding a load of feed if you can load the grinder evenly . And the big thing set it back to being real close to stock or 10% above atleast for the first fifty hours . And make sure that engine temp is at operating temp.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
