There is a possibility that the gen is not connected to the battery. This would cause the gen to teat good but not charge. With it running, and all wires connected as originally wired, run a wire from the battery to the gen Armature post. (not field) if it sparks, that indicates the gen is capable of putting out voltage do not leave it on there. If no spark, make sure the gen is grounded at the frame to bracket to engine. If it is for sure grounded try it again. If no spark, Ground the field terminal (leave things all connected as before) if still no spark, the gen is suspect. If it sparks when first tested (nothing but the first temporary jumper) then I suspect the amp gauge is open (defective) or the regulator's cutout relay is not closing. To check this use a solid copper wire to jump from the Gen terminal on the regulator to the Bat terminal on the regulator. If it now sparks and shows charge, the VR is not closing. (Repair is pretty intense, but best done if experienced.) replace the Regulator. If still no spark at the jump and no charge it further condems the amp meter. (you are sure all connections are shiny and tight!!!) Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
