Re: Farmall M trany/cluch problems
Posted by rhtx55 on March 14, 2012 at 16:21:20 from (207.119.62.3):
In Reply to: Farmall M trany/cluch problems posted by Nick Roepke on March 12, 2012 at 10:55:19:
Since both pedals are on the same shaft, I would first check the bushings for that shaft in both sides of the tranny housing. They either need lube (grease) or one of the spacer machine washers was left off causing either pedal to rub against the tranny housing. This would cause the 'click" noise, had the same issue on a 46 H that drove me crazy until I replaced the bushings, had the shaft turned & clutch pedal rebushed to match the shaft.
The grinding noise you will need to checking your clutch pedal free travel at the throw out bearing, sounds like when the pedal is released the forks are either still contacting the throw out bearing ( rubbing) or the set screw on the clutch pedal needs adjusted also.
Best I can come up with.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
